2004 Automatic 6 Cyl wnt switch to 2nd gear...
I have an 04 Sonata, problem seems to be it will not go into 2nd gear, keep in mind it is an automatic. It will hit 3000 RPM's then start all over again, once it hits 3000 I get up to 20MPh then it drops me down to 10MPh and I have to rev it back to 3k, but it will not go further than that. Any ideas or suggestions would be appreciated, Thanks...
2003-2004 SONATA 2.7L
2-3 SHIFT FLARE IMPROVEMENT
“38. EF F/L 2.7D AT SHIFT FEEL IMPROVE”
DESCRIPTION:
This bulletin provides a procedure to reprogram the transaxle control module (TCM) software in 2003-2004 MY Sonata vehicles with 2.7L engines using the Hi-Scan Pro. (This update should be able to be performed with GDS now)
DESCRIPTION:
The Sonata 2.7L TCM reprogramming provides the following refinement updates:
• Reduced 2-3 shift flare (engine speed increases during the 2-3 shift) during the first acceleration after a cold engine start
• 1-2 and 2-3 shift quality improvement (harsh shift improvement)
• Delayed shift feeling improved (from park to drive or park to reverse)
VEHICLES AFFECTED:
• Model: 2003-2004 SONATA vehicles with 2.7L engines and automatic transaxles
• Affected vehicle production date range:
-- Produced from November 29, 2002 through December 14, 2003
Then follow up with this program --
2003-2004 SONATA 2.4L/2.7L TCM REPROGRAMMING INSTRUCTIONS FOR DRIVELINE BUMP BETWEEN 2-10 MPH
"62. EF 2.4/2.7 DRIVING FEEL IMPROVEMENT"
DESCRIPTION:
Some 2003-2004 Sonata vehicles with 2.4L and 2.7L engines (see affected VINs and
production dates below) may experience a mild, one-time driveline bump when
accelerating from a stop after the vehicle has been parked for more than one hour.
The driveline bump will be felt as one, two or three successive bumps between 2-10
mph and will occur only once for each driving cycle. The driveline bump will not occur
after the engine and transaxle are at normal operating temperature.
This bulletin provides the procedure to reprogram the Transaxle Control Module (TCM)
software in 2003-2004 Sonata vehicles with 2.4L and 2.7L engines using the Hi-Scan
Pro. (should be able to use GDS here too)
VEHICLES AFFECTED:
• Model: 2003-2004 SONATA 2.4L and 2.7L vehicles.
- 2.7L: Produced from Nov. 03, 2002
- 2.4L: Produced from Nov. 02, 2003
• Affected VIN range:
- 2.7L: Produced from KMHWF35H03A798938 (With TCS)
Produced from KMHWF35HX3A798901 (Without TCS)
- 2.4L: Produced from KMHWF25S14A982051
__________________________________________________ _________________
After programing, disconnect battery for couple minutes to reset adaptive, hopefully ATF is good and hot when program done so right adaptive reset, they can do the initial learn start-up before releasing car.
ftasux
May 29, 2015 01:17 PM
rokuez
May 12, 2008 04:56 PM
csmpez
Mar 24, 2008 12:36 PM
