2005 Sonata 2.7L V6 crazy temperature indicator
Old Jul 13, 2025 | 02:14 PM
Samialamir's Avatar
Default 2005 Sonata 2.7L V6 crazy temperature indicator
Hello everyone, I have been trying for 6months but without any luck.
I have a frustrating problem with the temperature indicator in the dashboard it goes up when the temperature of the engine is normal that happens only at night 🌙 🙃.
I have an OBD and the readings are totally fine 91° ~ 97° the engine performance and fans works are fine everything is working smoothly even when it shows that the car temperature is high in the dashboard.
A year ago i have added one more ground wire between the chassis and the engine and it stays fine but in the last 6 months the same problem appeared noting that I cleared all the ground points inside the car or in the engine.
NOTE
  1. I have replaces the temperature sensor with no luck.
  2. The interior lights slightly dimming when I turn the head lights on.
  3. The AC blower on the highest level gets a bit weaker when I press the AC on or turn on the lights. It become normal when I press AC off or turn off the heads up lights.
I'm kindly requesting your support with any solutions out of the box. Cuz I'm losing my mind each time.
Thanks.
alysia
Aug 11, 2022 05:44 PM
kreggani
Apr 10, 2022 04:16 PM
Amanda Bergman Edwards
Jul 27, 2020 04:38 PM
maabel
Mar 30, 2009 12:39 AM
mikeyhd
Sep 22, 2006 01:06 PM
