hyndai tucson ac problem
Old Apr 10, 2022 | 06:39 AM
kreggani's Avatar
Default hyndai tucson ac problem
ac working only on start up and doesn't stop if the car is on. when i turn it off the ac doesn't work. But if i let it for 2-3 hours then i turn it on the ac work again normaly. any one knows the solution of this problem please ?
Old Apr 10, 2022 | 12:40 PM
Different year vehicles have different systems.
Need to know what year, manual or automatic climate control,
There are many things that can cause this problem and the only way to pin down the cause will require some testing and gauges to determine the cause.
Old Apr 10, 2022 | 01:52 PM
kreggani's Avatar
Thank you. Its 2015 automatic climate can you please help me on this
Old Apr 10, 2022 | 04:16 PM
We will try,
When you say it does not work,
What do you get when you turn it on?
Does the blower motor work ? Yes/no ?
If it does blow , does it only blow warm air?
Has any work been done to the air conditioning recently? If so, by who? and what did they do ?
When it does work, how long before it stops working correctly?
Without gauges to check the level of refrigerant charge, we have no idea if it is under or overcharged.
There are a few sensors, that need to be verified working correctly and this requires a capable scan to to do this.
Alexjordan22
Aug 22, 2019 05:40 AM
Chris M.
May 15, 2018 07:32 AM
Florida_Orange
Jul 10, 2014 04:35 PM
ksojerio
Apr 25, 2012 12:46 PM
