2006 Sonata Antenna Question
Old Apr 26, 2007 | 12:01 PM
jadorus's Avatar
Default 2006 Sonata Antenna Question
Hello All,
I recently bought and personally installed a Sirius satellite radio and am trying to use it in my Sonata via the FM transmitter. However, I live in Pittsburgh where there is plenty of hills and interference with FM signal.
I believe that this issue can be resolved if I use the External FM Extension. This is something that plugs into the back of the Sirius unit, and then you're supposed to route the wire to get the opposite end as close to the car's built-in antenna as possible. The problem is, the 2006 Sonata supposedly has a "element antenna" and it isn't apparent where exactly it is!?
I assume that this is like most newer antennas, and it's built into/across the rear windshield so that it almost looks (or blends in) with the stripes of the defogger. If someone can verify (as I called the dealer where I got my car, as well as numerous car audio installation places) this?
Also, if anyone currently HAS Sirius working "well" (without a bunch of FM interference) in their Sonata I'd love to know how you did it (where you situated the unit, ran the wires, chose to do a direct connection from Sirius to the car stereo, etc).
Thank you all in advance for reading this post and/or for your responses!
Old Apr 26, 2007 | 02:45 PM
jadorus's Avatar
Default RE: 2006 Sonata Antenna Question
All,
Thanks to all who read my post, and it appears I figured this out on my own via trial/error.
The manual does (very briefly) say that the antenna for the 2006 Sonata is "in the rear glass" so I ran the external FM transmitter wire through the paneling back to the rear window, and am having a MUCH better experience with the wireless Sirius setup.
Again, thanks to all!
Old May 3, 2007 | 11:22 PM
WheelBroker1's Avatar
Sorry that I didnt see this sooner and give you the same info you found out on your own..good subject that our members will now know....Thank You for your answers...
WheelBroker1
proque_cu
Nov 21, 2016 02:49 AM
CndRedCoat
Dec 12, 2010 12:51 PM
jassmith
Aug 24, 2007 12:34 PM
jnezon@hotmail.com
Aug 13, 2007 09:53 AM
jri1017958
Jul 31, 2006 03:53 PM
