2007 Sonata V6 Engine Noise
Old Nov 30, 2007 | 07:55 PM
Dave034's Avatar
Default 2007 Sonata V6 Engine Noise
I have an '07 Sonata 3.3 that is noisy at cold start-up. If the ambient air temp is less than about 15 degrees, you can hear what almost sounds like piston slap at idle for about 20 seconds. Cold start up with air temps over 20 degrees, there is no noise until you put it in gear and get a load on the engine - then the noise is evident for several seconds and then fades away. Anyone else experience this?
Old Dec 3, 2007 | 10:31 PM
hyundairecov's Avatar
Default RE: 2007 Sonata V6 Engine Noise
The noise is chain tensioners.
georgejw22
Sep 2, 2021 03:16 PM
tonypom
Nov 29, 2007 08:08 PM
sonnyboy
Jan 14, 2007 01:52 PM
freddydj1
Jul 25, 2006 11:53 PM
jims68
Jul 7, 2006 06:38 PM
