2008 Sonata hard start/ blower cuts out
Old Sep 20, 2017 | 03:15 PM
Spikepaga's Avatar
Default 2008 Sonata hard start/ blower cuts out
Hello all! 2008 V6 3.3 model
was hoping I could get some help with this problem
Car is not wanting to crank easily. It eventually does but the a/c blower cuts during driving and the interior lights flicker.
I have ordered a positive battery cable, but am not sure if this is the problem. Or if there is a workaround with regular battery cables until the OEM cable comes in
Old Sep 21, 2017 | 09:13 PM
avisitor's Avatar
So the car doesn't crank easily?
Do you mean the engine cranks but doesn't start?
Or do you mean the engine doesn't crank and therefore won't start?
Not cranking is a different system to troubleshoot
Cranking, no start is a whole different ball game
Let's see, you're about to replace the positive battery cable
Then there was probably some dirt or corrosion on it
This would mean that the grounding points also need to be cleaned
Negative terminal on battery needs to be cleaned
And the cable from the negative battery post to the chassis grounding point needs to be cleaned too.
It usually goes under the battery tray.
welshsanta
Jul 14, 2013 03:52 AM
saveit
Jan 4, 2013 12:17 PM
rkneeland
Sep 23, 2010 10:32 AM
sweeth20
Jul 24, 2009 02:54 PM
cromepony
Jul 3, 2006 08:48 PM
