2012 Sonata 2.0 A/C Module burnt
I would check the resistance of the compressor control valve, also the resistance of the fan control relay.
I.m not sure if it controls the blower motor? Also maybe the blend motor ? Is the module one that controls the climate control?
I apologize for not getting back sooner. Yes this is the CLimate control module. Facts I didnt state before. Compressor, expansion valve and dryer were replaced about 6 weeks befor the first module burnt. IS there anything there that should be checked as far as electrical connection. The one thing I dont understand is there are no fuses being blown.
It sounds like one of the devices connected to the module is drawing too much current, partially shorted, not bad enough to blow a fuse, but bad enough to overheat the module.
You have to measure the resistance of things like the compressor control valve, blend door motor, blower motor etc... and find which has resistance too low compared to spec.
I tried to post earlier today, but my tablet was having issues.
I really appreciate your help.
You would (for instance) disconnect the wires to the AC compressor and insert your probes in the connector to the compressor and read it's resistance.the same for the other devices connected to the module. The resistance should be listed in the shop manual.
I have been looking through my service info, but can't find the resistance info in what I have. I will have to look some more, I have to get up early, and have to turn in..
I do have the pinout of the module though. You could take apart the burned module, and see what area burned to see what it controlled. Possibly the blower control mosfet?
Is it burned at the 6? wire connector? There should be a fuse for the the system, if it were the wrong size it could cause the module to pop before the fuse.
A pic of the damage would help.
I found fuse info:
By driver's knee
ROOM LP (POWER CONNECTOR) 10A
Instrument Cluster, Driver/Passenger Door Lamp, Ignition Key ILL. & Door Warning Switch, BCM,
Tire Pressure Monitoring Module, A/C Control Module, Room Lamp, Front Monitor, Glove Box Lamp,
Data Link Connector, Vanity Lamp LH/RH, Auto Light & Photo Sensor, RF Receiver, Overhead Console
Lamp, Clock
A/CON 7.5A E/R Fuse & Relay Box(Blower Relay), A/C Control Module
Engine compartment:
fb A/CON 10A A/C Control Module (Auto)
RR HTD IND 10A A/C Control Module
I found fuse info:
By driver's knee
Lamp, Clock
Engine compartment:
