2015 Sonora smells like burning oil
I’ve looked all over and see no oil leaking any where.
Mine just started doing the same with a little under 80K miles. It's a noticeable smell and the oil level was dropping rapidly (about a quart every 200 miles). The Theta II is known for having issues with oil and knocking. Take it to the dealer and request an oil consumption test. They will top you off and have you come back in 1000 miles to check the burn rate. If it's too much they will do a 24 hour soak to clean the rings, then top you off again and come back in another 1000 miles. If that doesn't fix it you'll be getting a new engine covered by the lawsuit. It's a pain, but at least Hyundai is taking care of people.
