EPS and Traction control light on after replacing steering coupling
Old Oct 9, 2017 | 02:20 PM
Cgroves81's Avatar
Question EPS and Traction control light on after replacing steering coupling
Hey all!,
First time poster here. My wife's car had that "awesome" steering wheel clunk that is associated with a chewed up power steering coupler. I dropped the steering column unscrewed those black bolts on the power steering motor with some t-30's got everything back together and when I started the car to basque in all my glory, the EPS and traction control light lit up and now I have no power steering and the lights won't go off. Anyone got any advice?
Old Apr 10, 2019 | 06:08 PM
Shenandoah Troumbley's Avatar
Originally Posted by Cgroves81
Hey all!,
I am having the same problem after replacing the steering coupler. How did you fix it?
Old Jul 14, 2019 | 06:24 PM
mark 63's Avatar
Smile no power steering and tcs
I realize that this is an old post, but I ran into this same problem today and can tell everyone that the problem I had was caused by the accidental disengagement of the motor connector on the module when dropping the steering column. After reconnecting the module, still had the same issues. The code in the module still stated that the motor was shorted or open. Once the module sees this code, It needs to be cleared with a proper scan tool.Logic tells me that this is a fail safe default .If my thought process is flawed please let me know. Maybe some of the hyundai techs will chime in.
Old Aug 19, 2019 | 09:10 AM
Cooldriver's Avatar
Default Same issue
Hey all!,
Hello, I have ran to the same issue after replacing the coupler. Can you please tell me what have you done to fix it? It is driving me nuts
Old Aug 19, 2019 | 09:12 AM
Cooldriver's Avatar
Hello. I ran to the same issue. What have you done to fix it please?
Old Aug 19, 2019 | 02:48 PM
mark 63's Avatar
Default eps/traction lights on
To fix the problem I had to reconnect the steering motor power connector and take it to a shop to clear any codes that were stored in the module. I presume that any time the module see's a motor power fault problem, that the system automatically defaults to manual mode until the problem is corrected and the code/codes are cleared.Hope this helps.
Old Aug 20, 2019 | 07:44 AM
Cooldriver's Avatar
Default Thanks for the reply
Do you mind if I asked if you had to take it to hyundai dealer specifically and gow much did it cost you?
Old Aug 21, 2019 | 08:13 AM
mark 63's Avatar
I paid 70.00 USD for their service from a local full service shop(. not a dealership)
SportsDude
May 11, 2022 01:07 PM
sgreiner_elantra
Aug 12, 2019 09:15 AM
pecliff
Jun 27, 2010 10:33 PM
USAFA83
May 25, 2010 08:34 PM
ntc
Nov 26, 2009 12:17 PM
