Need help with 02 Sonata headlight alignment
Old Dec 8, 2008 | 07:07 PM
harikumarj's Avatar
Default Need help with 02 Sonata headlight alignment
Hi Hyundai'ites,
I've an 02 Sonata (2.4L base model). I replaced the front driver side headlight and the beams are off-gear since then. After doing few searches, I found that the alignment of headlights would have changed. Searching on the net gives few tips, but are not too relevant to Sonata. If anyone has insights on how to set this right, do let me know.
Old Dec 8, 2008 | 07:14 PM
ken99's Avatar
Default RE: Need help with 02 Sonata headlight alignment
Instructions are provided on pages 6-17 through 6-19 of the owners manual.
Old Dec 30, 2008 | 08:28 PM
harikumarj's Avatar
Thanks Ken for your response.
I found that the issue was not due to alignment. I had not clamped the bulb properly. I found it when I was trying for the screw (or whatsoever) that needs to be adjusted for alignment issues. I did not find any screw kind of that can be adjusted. I removed the bulb completely from its socket and inserted it properly and this time the clamp was a lot easy to put.
Old Dec 30, 2008 | 10:04 PM
ken99's Avatar
I am glad you were able to get the problem solved.
peetb90
Dec 27, 2013 09:42 AM
gcleeton
Dec 27, 2011 10:42 AM
JohnRossitter
Nov 21, 2007 07:33 PM
tcarr925
Aug 18, 2007 03:48 PM
macnolos
May 17, 2007 12:28 PM
