Please help??
I have a 2004 Sonata 98,000+. Recently both of my foglights have stopped functioning. The indicator on the dashboard shows that I have them activated by the switch on the lever on the left of the steering column (same switch to turn on headlights) - but neither of them work.
NOTE: About 1.5 months ago, my transmission pressure line burst and spewed fluid all over the lower front of the engine compartment. After the repair, (by on-sight mechanic), I used CRC Brakekleen to dissolve and dry up residual transmission fluid. Not long after is when I noticed they weren't working.
Could it be related????
I tried replacing the fuse - nothing. I find it hard to believe that they are both burned out simultaneously.
Could there be another electrical problem that wouldn't blow the fuse but still kill the lights?
