Sonata 2016 door open light
Old Jul 28, 2021 | 10:20 AM
Elwerphaly's Avatar
Default Sonata 2016 door open light
Good evening to all, I got sonata 2016 2 months ago and just today when I unlocked the car I noticed that the door sign (light on dashboard) for the door behind the driver open although that door is closed!
I tried to find a pin or a switch but unfortunately no luck.
Any help pleeeease?
Old Aug 3, 2021 | 08:24 AM
David Snyder's Avatar
Since you have not gotten an answer yet I will tell u what I know. My boy's old Ford Taurus had the same problem.....door light on but door closed. I looked and looked for some kind of a switch but could not find it. Finally, for $20 bucks I downloaded a one month's subscription to a Mitchell car manual and then printed wiring diagrams for the door locks and windows etc. I discovered inside of the door lock assembly which is inside of the door panel, there is a light switch connected to the power lock mechanism......if that makes any sense. I bought a new switch from Ford for $12 bucks shipped. Although, it was a bear to install, I had to take the door lock apart, the door light now works properly.....my son did not thank me. Anyway, I know this auto is different than your Hyundai but since you cannot find a switch there is a chance your switch is inside of your door panel. By the was, when all else fails, get a manual! Good luck
Old Aug 3, 2021 | 12:10 PM
Sometimes a liberal shot of WD40 into the lock assy allows it to free up and work again.
Old Aug 7, 2021 | 03:49 PM
Elwerphaly's Avatar
Thank you so much for your help it's highly appreciated, and it's correct the switch is in the door lock.
Thanks again
Old Aug 7, 2021 | 03:50 PM
Elwerphaly's Avatar
Yup it's true and it worked for me.
Thanks for the advice.
lothian
Jan 30, 2020 07:59 AM
Florida_Orange
Jul 10, 2014 07:40 PM
brenner21
Apr 29, 2013 07:28 AM
frankcabanski
Apr 2, 2011 10:26 AM
Kalun47
Apr 1, 2011 12:23 AM
