Steering Noise: Loud Groan when Turning Wheel
Old Dec 21, 2018 | 10:12 AM
lothian's Avatar
Default Steering Noise: Loud Groan when Turning Wheel
2006 Sonata GLS
141k miles
Listen to the following audio files:
Inside Cabin
Under PSrack
What you hear is the noise created every time we turn the steering wheel in either direction, lock-to-lock. To capture these two audio samples, I elevated the Sonata on jackstands and turned the wheel slowly back and forth. There is zero vibration, stiffness, or suspicious sensations felt in the steering wheel and when push/pulling the tires. I feel zero vibration when I rest my hand on the power steering housing and pinion-and-valve assemblies while inducing the noise.
The "Inside Cabin" is the actual sound--at actual volume--we hear inside the cabin. The "Under_PSrack" is the actual sound from the area immediately adjacent to the junction of the power steering housing and pinion-and-valve assemblies. Notice that "scraping" sound that follows the groan noise? That's the sound of fluid-churn inside the steering rack--a noise I've never heard from a rack before. (I checked the reservoir--it's full and there is no air froth.) Visually, the steering components appear okay: no wetness, bellows are intact, nothing loose.
This problem began four weeks ago with intermittent, though identical, noise inside the cabin. Now, the sound is constant and occurs regardless of ambient temperature, load/unloaded wheels, engine running or off. The noise is plainly coming from some steering component, but I cannot identify the specific source.
I welcome experienced ideas, suggestions, add'l t'shooting steps to help me locate the source of this problem.
Old Dec 21, 2018 | 03:27 PM
allegretto's Avatar
Our '08 Sonata made some squishy sounds and over time developed leaks at the bellows. That indicated that the seals were gone. We had the rack replaced with a rebuilt one. It was different from your sound samples. But imagine the fluid being pushed passed the seals and possibly in either direction.
You could try flushing the whole system. Maybe new fluid is going to cure it. Hyundai and Kia want their customers to use their specific concoction of PS fluid. It's pricey, but at least you would know it is what supposed to be in there.
Or you could try Lucas Oil Power Steering Stop Leak. It contains stuff that swell rubber seals and makes them seal again.
Old Dec 21, 2018 | 04:21 PM
lothian's Avatar
The sloshing noise coming from the somewhere in the steering assembly is genuinely weird--I never heard that sound from a rack before. It's obvious the fluid is low in what is 'sposed to be a sealed system. But there none of the typical symptoms of failed seals: wheel slop, stiff wheel response, poor wheel return, PS fluid leaks, low PS fluid and/or froth in reservoir, pump whine. Nothing. Just the noise.
Nevertheless, my intuition is I gotta a failed internal seal. I'd rather rebuild the rack than replace it, but I can't source a seal kit for PS racks, and Hyundai doesn't offer such.
Old Dec 21, 2018 | 05:47 PM
allegretto's Avatar
Jorge529
Apr 23, 2013 08:28 AM
kerflumper3
Jul 4, 2012 12:50 PM
CoolElantra
Oct 2, 2010 04:29 PM
bluebabby
Aug 11, 2006 01:24 PM
catbeckster
Jun 8, 2005 01:23 AM
