Will only start with a jump
Old Jan 13, 2012 | 10:48 AM
Jav8996's Avatar
Default Will only start with a jump
Good morning,
I have a 2003 Sonata, 6cyl, just went over 100k miles. Two days ago the car wouldn't start. I jumped it and it started. Tested the battery and autozone said it was bad. Yesterday bought new battery and no start. Car will start again with a jump. What is causing no start? Is it possible that going over 100k miles caused cam position sensor to give? BTW, not pulling any codes. Any/All help is appreciated. This is my sole source of transportation. Thanks.
Old Jan 13, 2012 | 11:12 AM
Check the cables for being loose or corroded.
Old Jan 13, 2012 | 12:04 PM
Jav8996's Avatar
Will check the cables. To my recollection there was minimal corrosion but not much. Will make sure all is gone though. It seems to me that that may not be the only thing. After turning car off, I have no power whatsoever. No interior lights, clock, nothing.
Old Jan 13, 2012 | 05:38 PM
GuyHavingProblems's Avatar
I had a weird issue kinda similar with my 01 my problem was the power cable running from the positive post on my alternator to the battery corroded off. I had to run a new wire, it wasn't that hard but it sure was annoying.
P.S. Don't try to follow the wire with your hand if the engine is hot or even kinda warm, mine ran right next to the exhaust headers. Which i found out the hard way from underneath my car.
Old Jan 13, 2012 | 07:12 PM
Jav8996's Avatar
Okay, just checked and there was minimal corrosion. Cleaned whatever corrosion was there. Still no start. I'm going to try and jump the starter to rule out that. I'm also thinking the starter relay. Anyone have any other idea how/where to check that? Anyone have other ideas/opinions?
Old Jan 14, 2012 | 11:52 AM
Jav8996's Avatar
Solution: it was the starter relay.... I swapped it with another relay that was in the fuse box under the hood and the car started and kept starting.
Thanks for all the help.
steelsun
Mar 23, 2015 07:05 AM
pete90
Nov 13, 2008 07:30 AM
joymayland
May 7, 2008 01:14 PM
grackett
Jan 15, 2008 03:00 PM
vincewturner
Dec 7, 2006 01:44 PM
