Winshield washer pump problem!!!
Old Apr 1, 2009 | 06:40 PM
bucannon's Avatar
Exclamation Winshield washer pump problem!!!
Okay i have a 2001 sonata, the winshield washer pump didnt work when i got the car. first thing i thought was to check the fuses, i checked the fuses under the dash and under the hood, none were for the winshield washer pump that i saw. so recently i decided to get a new pump. i took the old one out cleaned the tank out and installed the new pump, filled up the tank and tried it but it didnt work, so i checked to see if the pump was getting power, and it was not getting power. i traced the wire for about a foot until it joined with some other wires in the factory harness, but coming from the same spot is some wires connecting to a block. did i miss a fuse, do i need to replace this "block", or do i need to run some new wires?
Old Apr 1, 2009 | 06:57 PM
jsinton's Avatar
Banned
Obviously you didn't find the fuse, for sure there is one. I can't find the diagram or I would try to tell you. Maybe somebody else can help you.
Old Apr 1, 2009 | 07:13 PM
ken99's Avatar
Fuse Amperages Circuit protected
26 15A Wiper motor, Washer motor
Fuse #26 under the dash feeds the washer, but it also feeds the windshield wipers. If the wipers are working then the fuse is OK. That leaves a broken wire or a bad switch in the column. The switches are known to go bad on these cars.
Old Apr 1, 2009 | 08:18 PM
bucannon's Avatar
yes the wipers work, i do remember seeing a winshield wiper fuse, but it was fine obviously. the switch in the column still turns on the wipers so i dont think that is the problem.
Old Apr 1, 2009 | 09:53 PM
ken99's Avatar
It's a multi-function switch with different contacts and wires involved. No, the washer part could still be bad without affecting the wiper function.
Old Apr 14, 2009 | 05:09 PM
bucannon's Avatar
what is the best way to see if that is the problem? should i take the switch out and check everything out. or should i go ahead and change the little block that i believe is connected to the pump?
grlgeorge
Feb 6, 2012 12:02 PM
Doitall Dad
Dec 18, 2010 10:19 AM
bumbleberry
Jan 18, 2009 10:04 PM
sarahinmedford
Jan 2, 2009 02:22 PM
pneandy
Jun 6, 2007 11:16 AM
