01 tiburon code p0501 speedometer
Old Sep 21, 2013 | 04:12 PM
shark01's Avatar
Default 01 tiburon code p0501 speedometer
About a week ago I was driving 01 tiburon when speedometer crapped out and shortly after, CEL came on. When I got home, without speedometer, I scanned and pulled code p0501. From other posts, I gathered that speed sensor needed replacement and I ordered new one. Tranny is manual 5-speed and I pulled air box to find a sensor on top of trans. case. Problem is that sensor I am looking at in vehicle has 2 "holes" for terminals/pins and is oval shaped. Replacement I received (genuine OEM #96420 2D501) is only one that is listed anywhere online, and has 3 terminals/pins triangular shaped.
Either I am looking at the wrong sensor in vehicle- if so, please give exact location and how to remove it- or, I have the wrong part- if so, please advise correct part # for 01 tiburon, 5-speed manual, 2.0L DOHC engine.
Please respond ASAP due to no speedometer & THANKS!
Old Sep 27, 2013 | 10:47 AM
shark01's Avatar
I had the correct part, but looking at wrong sensor. Speed sensor is at rear, lower part of engine compartment directly down under throttle body and on top of tranny. I removed airbox and air ducts and replaced in about 10 mins.
Old Sep 28, 2013 | 05:45 AM
Thanks for the update !
ElantraGLS
Sep 5, 2015 05:42 PM
CptnNemo
Jan 2, 2013 09:49 PM
BigCamWS6
Aug 7, 2012 07:44 AM
big mamoo
Apr 7, 2012 06:37 PM
conrad.doucet@ns.sympatico.ca
Feb 6, 2012 10:24 AM
