2000 Tiburon Problem
Old Mar 31, 2008 | 03:31 PM
nmack's Avatar
Default 2000 Tiburon Problem
My daughter's 2000 Tiburon seemed to slip out of gear. The mechanic pulled a code stating incorrect gear ratio (4th). Does anyone know what part needs replacing?
Old Mar 31, 2008 | 03:42 PM
ken99's Avatar
Default RE: 2000 Tiburon Problem
Is this a manual or an automatic transmission? Which engine? It would also be helpful if you could remember the exact error code (e.g. P0720 or something like that) that the mechanic recovered with his scanner.
Old Mar 31, 2008 | 05:16 PM
If it's a 2000 RD Tiburon it must be the 2.0L Beta 4-cyl engine. However, like Ken said, knowing if it's an auto or manualtranswould help.
Since you said 4th gear I assume the code is either:
P0730 Incorrect Gear Ratio
P0734 Gear 4 Incorrect ratio
Things to check:
a. Check the pulse generator A and B connector
b. Check the pulse generator A and B
c. Kickdown brake slippage
d. Check the end clutch or control system
e. Check the pulse generator wiring harness
oncas
Apr 16, 2011 12:48 PM
bryanbuchi
Feb 27, 2009 06:42 PM
ArmedsouthernEr
Feb 16, 2008 11:48 AM
my2ktib
Jan 1, 2008 11:53 PM
brianphillips
Apr 10, 2006 12:04 PM
