fuel filter and check engine trouble
Old Aug 27, 2008 | 09:30 PM
logtog555's Avatar
Default fuel filter and check engine trouble
Can anyone tell me where to find my fuel filter in my car. i have a 2003 tiburon v6 2.7. Many people have told me its in the gas tank, so i look and theres no filter there. The filter needs changed badly, and i believe thats why my check engine light is coming on.I plugged in my little computer and i cam up with three engine codes, P0507, P0121, and P0101 and they all were saying (pending). So any help would be greatly appreciated.
Logan
Old Aug 28, 2008 | 06:48 AM
Default RE: fuel filter and check engine trouble
The filter IS in the tank, attached to the fuel pump. It's just a "sock" filter. Ther is no "in-line" filter.
P0101 = Mass or Volume Air Flow Circuit Range/Performance Problem
P0121 = Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance Problem
P0507 = Idle Control System RPM Higher Than Expected
As you can see, none of the codes has to do with a dirty fuel filter. Get your MAF cleaned and have the TPS and IAC checked.
Paulus
Mar 11, 2013 10:29 AM
Aggie_1990
Jan 17, 2012 12:28 PM
2001accent
Sep 13, 2011 08:54 PM
Smog23
Apr 19, 2011 09:38 PM
bglick12
Jul 16, 2010 06:19 AM
