tiburon trans
Old Feb 25, 2009 | 03:19 PM
mattsaari's Avatar
Default tiburon trans
have a 98 hyndai tiburon that has problems with the trans the problem is when u go from r n or p to drive it takes up to a minute to engage the trans is not slipping at all and it works fine if u leave it in drive such as pulling up to a stop sign if anyone has a clue as to whats wrong your input would be appreciated
Old Feb 25, 2009 | 04:34 PM
jsinton's Avatar
Banned
Did you check the fluid level? How about the condition of the fluid? Did you do a flush?
Old Feb 26, 2009 | 10:49 AM
mattsaari's Avatar
yea i checked the fluid it did not smell burnt and was pretty red still i did not flush it but u would think if it was plugged it would be slipping as well unless the valve bodys are really dirty maybe try some trans saver?
Old Feb 26, 2009 | 09:32 PM
mattsaari's Avatar
when i had the vss replaced would they have to add fluid maybe theey didnt use the hyndia specific stuff and used standard atf and plugged up the valve body would this be a possable cause?
Old Feb 26, 2009 | 10:23 PM
jsinton's Avatar
Banned
Oh, yeah. Using standard trans fluid is bad. I think it's more a problem with being bad for the seals, although it's possible the valve bodies are sticky from some gunk. I wouldn't do the tranny doctor stuff, I'd do a proper flush and replace with correct fluid.
Old Feb 26, 2009 | 10:32 PM
mattsaari's Avatar
What fluid does this car take and i have a trans laying around is there any sesors that are easy to replace that would be worth a try thanks again
Old Feb 26, 2009 | 11:01 PM
mattsaari's Avatar
I also want to add that it only does this after it has been drivin around a few times that day
Old Feb 27, 2009 | 04:52 AM
jsinton's Avatar
Banned
Actually, replacing the VSS doesn't require adding any new fluid. But you should still at least have it flushed, probably take the pan off and change the filter. You might find some metal in the pan. I'd hold off on the replacement just yet, it's not the easiest job. The sensors can be changed pretty easy, but they are expensive.
Are you sure it's got enough fluid? Like drive around in forward and reverse and then check it in neutral? The fluid is a Hyundai spec, not easy to find. I just go to the dealer for that.
Old Feb 28, 2009 | 08:52 AM
mattsaari's Avatar
I know you said not to use additives but due to the lack of money and the car having 200k on it i used about a half bottle of slick 50 and it cleared up the problem
Old Mar 28, 2009 | 06:01 PM
SheHateMe's Avatar
Not to dig an old thread up, but possibly when they did a flush of the tranny, maybe the old tranny fluid was the only thing keeping it running well. I've seen some motors, held together with nothing more then engine sludge. If you did an oil change that motor would fall apart. Maybe the tranny liked having it's ****ty fluid in it?
seacliff
May 16, 2011 08:54 PM
blinkfan18224
Feb 10, 2008 11:56 AM
madindian1
Jan 4, 2008 06:38 PM
fourwjive
Dec 30, 2004 10:24 PM
frensel
Oct 20, 2004 10:13 AM
