Tiburon transmission
Old Aug 16, 2009 | 05:28 PM
autoslave's Avatar
Unhappy Tiburon transmission
Hi Guys,
I am stumped on how to get the gear box out of my 2000 tiburon. All unbolted but can only get it back about 2 inches. It acts like the presure plate pulls it back in. I have used brute force and no go. Can anyone help, Please. Autoslave...
Old Aug 16, 2009 | 06:38 PM
jsinton's Avatar
Banned
Did you remove the clutch actuator control arm? You have to remove it, or the forks will hold on to the release bearing. Just remove the one bolt on top and pull the arm off. It's the arm that the slave cylinder presses.
If you did remove it, then there also is a bracket which holds the connector for the crankshaft sensor. Make sure you take off that bracket.
Old Aug 16, 2009 | 07:06 PM
autoslave's Avatar
Smile
Thank you. That is what I did not do.
thegerman1991
Jun 30, 2010 11:47 AM
gpballin20
Nov 11, 2008 01:35 AM
oldsalt
Feb 2, 2008 12:22 PM
sarah
Oct 16, 2007 11:46 PM
mibellatortuga
May 3, 2005 02:38 PM
