2007 tuscon clutch alignment
Old Sep 30, 2010 | 06:31 PM
wvhyundaiman's Avatar
Default 2007 tuscon clutch alignment
I bought a used 5speed tuscon on new years eve with 44000 miles on it the 1st clutch went out at 51000 950 bucks to have the dealer fix it that was in march last month at 75000 miles the 2nd clutch went out i ordered a sachs clutch kit that didnt come with the alignment tool where can i get one i've looked everywhere or does one from a different model work the same? plus is this a common problem with the tuscon as it is with the tiburon?
Old Sep 30, 2010 | 08:00 PM
Hyundai SST is a simple machined dowel to pass through the disc, with small nose to fit hole in flywheel..
Look around some of the local driveline places too. I have a dummy input shaft with splines and nose that sits into hole on flywheel.
Old Sep 30, 2010 | 11:34 PM
dunkyd's Avatar
For 40 years I've used a shaped wooden broom stick.
Old Oct 3, 2010 | 10:43 PM
thanks for the help I will try that. what i need mainly now is a copy of the shop manual that shows the procedure for removing the transmission on the 2.0l 4wheel drive tuscon so me and my buddy can get my car back on the road if anyone has one they can scan and send to me i would really appreciate the help
mray
Jan 21, 2011 11:16 AM
speeder
Mar 9, 2008 07:05 PM
JohnRossitter
Nov 21, 2007 07:33 PM
macnolos
May 17, 2007 12:28 PM
