Coolant Temperature Sensor (ECT) Location
Hello All,
The check engine light in my 2007 Tucson 2WD 2.0L came on and the temperature gauge started fluctuating. I have a trouble code of PO125. I am thinking it is the Coolant Temperature Sensor (ECT) but I can not find where that sensor is? Is there someone out there that can tell me the location? Showing me with a picture would be awesome! Thanks in advance.
How about you give this a little thought?
The ECT, engine coolant temp sensor only provides info to the computer for engine control and operation.
Since you don't have any problems there, but just with engine temp reading, I would suggest you go and purchase a new engine thermostat and gasket/O ring and replace a problem thermostat. .
