CV/Bearing replacement
Old May 3, 2022 | 07:14 AM
jabvfr's Avatar
Default CV/Bearing replacement
Hi all. I have just started to replace the left outer CV and wheel bearing on my 2004 Tucson CRDi 4WD. Unfortunately the CV that I received was not correct. The technical department gave the part number for the CV which has 27 teeth on the outer shaft and 25 splines on the inboard. The CV I removed has 26 splines inboard so I have had to order another CV. Unfortunately, because I had already fitted the new boot and clip, I cannot return the item as it is classed as 'fitted'
So I carried on and replaced the wheel bearing and will also change the anti-roll bar bushings which are quite loose. I had a nightmare getting the old outer race out of the hub carrier as the outside of the carrier has a lip and so there is no way to press on the outer bearing. After much foul language and bruising I finally got it out, but is there anyway it can be done easier?
TIA.
John
Old May 3, 2022 | 08:10 AM
There are some good reasons for purchasing parts on line, but there are some bad ones too.
Most shops can't afford to tie up vehicles waiting for parts so they go to local places and these days dealerships.
At a dealership they usually need the VIN , pull up the parts info and you may pay a few dollars more, but you get the right parts the first time and the quality is there,
Old May 3, 2022 | 08:37 AM
jabvfr's Avatar
I gave them the VIN and they assured me it would fit. Unfortunately they were wrong in this case
Old May 3, 2022 | 10:39 AM
Hard to believe since they have access to all the build info related to VIN, did they provide any explanation why this happened?
If you are referring to the bearing outer race , usually there is enough of a lip to drive it out with a bar.or punch. The critical part is installing it without putting any pressure on the inner race and possibly destroying the bearing assy. You can use the old outer race ti drive the replacement in.
Old May 3, 2022 | 12:24 PM
jabvfr's Avatar
There was no lip I could get to, I ended up having to drive at an angle on the curved race facing until I got enough lip showing below the rim of the carrier. Judicious use of heat and some brute force worked eventually.
I always use the old outer race to drive in the new ones on the press
They did not give any reason why it was the wrong part, just the statement that I could not return it as it was 'not new'.
I wonder if it is possible someone in the car's previous life may have fitted a different drive shaft?
djdonte
Feb 6, 2022 04:02 AM
mamaganoush
Jun 15, 2020 11:05 AM
new28868
Jul 9, 2019 10:38 AM
bernd
Mar 12, 2009 10:35 AM
sparxx
Mar 26, 2007 11:32 PM
