Front suspension noise
Old Oct 22, 2008 | 06:30 PM
CobraTwo's Avatar
Default Front suspension noise
I have a 2007 Tucson with the 2.0 liter engine. It just started making a creaking sound in the left front when i turn the wheels. I can't find anything in the owners manual about grease fittings. Are there any? Or do I need to go back to the dealer? Any suggestions?
Old Oct 22, 2008 | 11:28 PM
ken99's Avatar
Default RE: Front suspension noise
The short answer is "no". I have not seen a grease zerk on any car in almost 30 years, at least on an OEM part. Some aftermarket parts, like tie rod ends, sometimes have zerks to grease.
Any suggestions?
I would be most concerned about a dry CV joint. Crawl underneath and inspect the CV boot, looking for splits or cracks where grease has escaped. The sound could also come from the ball joint on the lower swing arm, the tie rod end or the upper strut. Have someone (you trust) turn the wheels while you are under there and listen for the source. Yes, you may have to take it to the dealership is it gets worse over time.
lavarc
Apr 7, 2012 03:30 PM
GregMurray
Mar 21, 2012 05:08 PM
patchman
Dec 9, 2010 08:37 AM
GOLD07
Mar 9, 2007 07:17 AM
freddydj1
Jul 25, 2006 11:53 PM
