Hyundai Veracruz This crossover combines the functionality of a minivan in a sleek exterior with luxury qualities.
ground loop isolator
Old Apr 8, 2021 | 10:40 PM
doug.crabb1@gmail.com's Avatar
Default ground loop isolator
Hello, trying to fix my constant buzzing sounds coming through the sound system. Can someone tell me what, how, where do i get this ground loop isolator for my stock 2007 hyundai veracruz,glc, awd
Thank You
Old Apr 16, 2021 | 01:42 PM
Sometimes, a filter capacitor will filter out the RFI if connected to the power supply side of the equipment.
That is if,,,,,,it is originating from the vehicle and not some outside source.
Old Apr 16, 2021 | 01:57 PM
Welcome back Hanky. My research and answer to this is another jury rig solution. take out the radio from the dash area, unplug the RCA cords, wrap speaker cable all around all RCA plugis and secure the wire. plug RCAcables back in, re-install radio unit back into dash and secure dash inserts.DONE. wHAT DO YOU THINK?
Old Apr 17, 2021 | 12:13 PM
It's your vehicle and you should do as you choose.
However, I believe it is the long way around and am not sure it will solve the problem.
When vehicles had DC generators it was common to install a capacitor to filter out the noise from the commutator on the generator. Alternators don't have that problem.
All you would need to do is to connect a noise suppressor (capacitor) . It is a lot easier and quicker,, if it works, again depending on where the RFI is originating.
Something to think about,
Spark plugs didn't always have built in resistors to reduce noise in a radio. Then they came up with carbon impregnated spark plug wires and resistor plugs.
Don't know what is presently in your vehicle , if there are resistors built into the plugs. What do you think?
Old Apr 18, 2021 | 08:57 AM
Questions, always questions,
This sound system,is the interference coming from outside stations or from when you play music from an interior supplied source?
If it is interior, there may something with the system itself. If it is from outside transmitted stations, sometimes when water gets into the antenna mountings/external connections it will diminish reception and introduce local frequency interference that the receiving section picks up.
longdriva92
Dec 7, 2008 06:43 PM
accent0002
Nov 10, 2007 09:03 PM
bmkotian
Jul 4, 2007 06:00 AM
jtaylor
Apr 2, 2007 12:53 PM
Nauticus
Dec 8, 2005 07:49 PM
