Hyundai Veracruz This crossover combines the functionality of a minivan in a sleek exterior with luxury qualities.
Oil leak onto alternator
Old Nov 23, 2020 | 08:22 AM
Painter's Avatar
Default Oil leak onto alternator
Oil is leaking onto my alternator. Is there a recall for this?
Old Nov 23, 2020 | 12:29 PM
Because all vehicles are not the same , it is important to know the year, model , mileage and some of the recent maintenance work done.
If we were able to actually see the engine , it would be a lot easier to offer any suggestions.
It's kinda like going to the doctor and saying I have a pain. Helps to know where, when, what may have brought the pain on etc. Hope you understand, thanks..
Old Nov 23, 2020 | 04:17 PM
Painter's Avatar
It's the front valve cover gasket. It's leaking onto the top of the alternator. I guess I will get a new gasket and replace it. Anyone find a good sealant to put on the gasket to help the seal?
I was going to use Permatex, but if someone knows of something better, I am open for suggestions
Sorry, it's a 2012 Veracruz
I called a dealership and they told me that the person I bought this from already had the recall done.
Old Nov 23, 2020 | 06:46 PM
Some engines use a gasket and some use only a gasket maker material.
There is a Permatex prodcuct called RTV black. If you need to use any adhesive with a gasket use it sparingly and make sure the surfaces are very clean.and dry.
If your engine is filled with a synthetic motor oil, there is a special Permatex (in a violet tube) product for use with synthetic oil and will hold up well.
Go slow and carefully and all should go well.
Old Nov 23, 2020 | 08:29 PM
Painter's Avatar
Thanks.
I Will look for the violet Permatex.
Old Dec 3, 2020 | 12:07 AM
Jennifer Murtaugh's Avatar
Yes there was a recall, i had the same issue on my 2011, got it entirely fixed for free and reimbursed for the battery and alternator i bought as well as the towing fee.
Old Dec 3, 2020 | 07:48 AM
Thank you for the info and update.
stokelife
Nov 24, 2019 06:16 AM
piuric
Aug 30, 2019 07:30 PM
veracruzveracruz
Aug 24, 2017 04:46 PM
Fatboy58
Jan 26, 2016 10:34 AM
lkbolles
Oct 2, 2014 04:03 AM
