Hyundai Veracruz This crossover combines the functionality of a minivan in a sleek exterior with luxury qualities.
Side mirror stuck
Old Jan 8, 2020 | 04:48 PM
jocefunnyfarm's Avatar
Default Side mirror stuck
Hey guys!
New here.
Bought a Veracruz not too long ago.
My problem:
Drivers side mirror is being pointed up. I can move the mirror with my hand manually but once i let go the mirror goes back up as if i had the up toggle switch pressed in.
I've tried, after manually moving mirror all the way down, pressing the down toggle switch. It stops it from continuing up but doesn't come down. I let go the down toggle switch and mirror continues up.
Any ideas?
Thanks!
Old Jan 8, 2020 | 09:25 PM
avisitor's Avatar
You will have to take it apart to see what is wrong inside the mirror.
Seems like there is a constant power to move the mirror up??
Old Jan 8, 2020 | 09:28 PM
That's that's a perfect description of the problem, there's always power to the up toggle switch.
Old Jan 9, 2020 | 10:45 PM
avisitor's Avatar
Well, seems like the side mirror was smacked then you have to open it up to see what happened inside to cause this condition
Old Jan 10, 2020 | 05:22 AM
I could be wrong on this ,but the mirror only does what it is told to do and it is doing just that.
If the mirror control switch is malfunctioning and always telling the mirror motor to go up ,that could be what is happening.
I would suggest , start checking at the switch and confirm it is not stuck in the UP position. It may look OK physically, but be stuck or broken internally.
Sometimes water gets in there and strange things begin to happen.
parisaccent
Jun 11, 2024 01:48 PM
emserra
Nov 20, 2023 01:16 PM
FleaBag
May 2, 2020 07:45 AM
nys3121
Mar 17, 2007 06:20 PM
stiles88
Mar 30, 2006 08:30 PM
