Cabin fan runs in 3rd&4th speed only-won't shut off
Old Nov 17, 2008 | 01:56 PM
MFF's Avatar
MFF
Default Cabin fan runs in 3rd&4th speed only-won't shut off
Blower cabin fan will not shut off- operates in 3&4 only- low speeds will not work.
Is there a relay? location?
Old Nov 17, 2008 | 02:04 PM
Default RE: Cabin fan runs in 3rd&4th speed only-won't shut off
ORIGINAL: MFF
I'm confused? Is the problem that the fan won't turn off or is the problem that it won't work on low speeds?
Old Nov 17, 2008 | 06:47 PM
MFF's Avatar
MFF
ORIGINAL: NovaResource
ORIGINAL: MFF
Both- off button does not work, fan button only controls 3&4 on hi-speeds- no low speed at all, when you shut off everything, the fan blows at top speed
Old Dec 29, 2008 | 08:55 AM
doallhyundai's Avatar
Did you ever resolve this issue? I'm having the same exact problem.
Old Dec 29, 2008 | 09:32 AM
MFF's Avatar
MFF
Have not -don't how to remove the dash- to get to the switch- if that is the problem?
[/align]MFF
Old Dec 29, 2008 | 09:49 AM
Thanks for replying. I've gotten some advice suggesting it's the blower motor resistor. You can see the shop manuals if you register at
http://www.hmaservice.com/
It's located behind the glovebox in my Santa Fe. Good luck and keep me posted. I'll reply if I get any more info.
mjmccaff
Aug 18, 2019 07:03 AM
Merlin Coryell
Sep 6, 2015 04:13 PM
ronnieoverholser
May 12, 2013 08:57 PM
saab90089
Jun 25, 2009 09:29 AM
rico
Mar 24, 2008 06:25 PM
