‘12 Sonata weird a/c problem- HELP!
Old Sep 23, 2019 | 12:20 PM
SuperJoe's Avatar
Default ‘12 Sonata weird a/c problem- HELP!
My shop has acquired a 2012 Sonata. The a/c works for a few starts, then it doesn’t. Found & pulled the fuse to check it -not blown! Reinstalled fuse-Air works great for 3-4 starts then quits cooling again. R&R fuse and repeat the last two sentences! Anyone else lived and fixed this purgatory?
Old Sep 23, 2019 | 05:51 PM
There is not too much that can be determined by the info you have provided.
There are many reasons an AC system will work and quit then work again. I would suggest you have the vehicle looked at to at least get some idea of what is working and what is not. This can't be done that easily without actually looking at the vehicle and see just what is working and what is not working.
Old Sep 23, 2019 | 06:31 PM
avisitor's Avatar
Yeah, turn it on and check the pressure of the refrigerant
If low then refill and see if it stays or not
If refrigerant pressure is okay then see if the compressor turns on or not
See if it cycles on and off
Laura Chandler Simmons
Jun 18, 2019 09:06 PM
Brad Snow
Jul 3, 2012 10:46 PM
hawk
Jul 16, 2010 06:12 AM
mrjgard
Mar 24, 2010 04:03 PM
Green97GLS
Jun 29, 2009 09:29 AM
