2001 sonata five speed manual transmkssion im puttia clutch in this car and scre d
Old Nov 15, 2017 | 10:57 PM
Ironwill's Avatar
Default 2001 sonata five speed manual transmkssion im puttia clutch in this car and scre d
Im putting a new clutch kit in the car but I screwed up and slowed thebottom gear selector shaft to be moved from the position it was in when removed it also has been moved away from side of trans how do I return selectors to neutral and b sure the fork is in correct place
Old Nov 16, 2017 | 07:27 AM
avisitor's Avatar
It is hard to understand what you did?
Did you move the stick shift into gear or into neutral?
What exactly happened?
Old Nov 16, 2017 | 07:38 AM
Ironwill's Avatar
Pulled linkage and remove d trans while sitting the selector shaft that sits lowest and to rear of top shaft got moved rotated and pulled out about 2 inches I need to find out what position the two shafts should b in when in neutral
Old Nov 16, 2017 | 01:29 PM
Ironwill's Avatar
OK so the trans was in hooked from cable linkage in gear apafently after removal the selector shaft got moved and was able to b skipped out away from teams so I need to know what position the top shaft holds when it is in a certain gear and what position the bottom shaft holds when it is in neutral hard info to find when u don't have the books anyway thank ymyou
DEBASHIS BASU
May 19, 2017 11:20 AM
NovaResource
Feb 27, 2012 10:19 AM
