2004 Santa Fe 3.5 sputtering and stalling
Old Aug 15, 2021 | 04:21 AM
Santafe20043.5's Avatar
Angry 2004 Santa Fe 3.5 sputtering and stalling
Going down the freeway engine just started sputtering and lost power,finally stalled. Would start right up but when put int gear would sputter and die. Had it towed back to the house. I don’t think it overheated. It will start and idle at 600-700 rpm but when I rev the engine will only go to 3000 rpm and then start dropping. When I put in gear will sputter and die, even just turning on the a/c. Car set up for almost 2 years, had to replace radiator but after that was driven about 150 miles before this happened. Any ideas about the cause?
Old Aug 15, 2021 | 07:00 AM
Might be a good idea to check and replace the fuel filter.
Old Aug 15, 2021 | 09:06 PM
Thanks. Sounds like it could be it.
Old Nov 19, 2021 | 09:03 PM
Question
Does anyone know what this doodad is? It sits right below the air intake of the throttle body? It’s for Hyundai 3.5.
Is this an idle air control valve? Sits under the throttle body air intake. Anyone know a part number? Can’t find it in Carparts.com or Rockauto.com. Could it be what’s causing my problem of not going over 3000 rpm and motor dies when put in gear. I’ve cleaned throttle body and changed MAF and TPS.
wtbbjb
Aug 28, 2012 07:50 PM
ron beauchamp
May 27, 2012 06:18 PM
struckproducts
Mar 19, 2012 06:21 PM
v1vrfly
Nov 25, 2008 01:35 PM
cjorden
Nov 19, 2008 02:19 PM
