Elantra 2002, 1.6 Gls
Old Jan 11, 2021 | 10:21 AM
Terryj's Avatar
Default Elantra 2002, 1.6 Gls
Hi
Ive got a problem with my Elantra 2002 model 1.6 Gls. Cranks but it wont start. Ive got power to coil but no spark from coil to plugs. Fuel pump is not turning on. Check fuses found that SNSR and INJ fuses got no power at fuse box. Also no power to injectors Please help
Old Jan 11, 2021 | 01:27 PM
avisitor's Avatar
Usually no spark and no injector pulse means the crankshaft position sensor is not working.
Do you have a check engine light?
Old Jan 12, 2021 | 12:17 PM
The easiest thing to do first is to check ALL the fuses. Without a wiring diagram, there may be a relay that controls power to the injectors and if that relay is not activated , no power to the injectors. Most relays usually have a fuse to protect the circuit.
A voltmeter or test light is the easiest way to get this done. Do you have either of these to utilize?
Old Jan 12, 2021 | 12:27 PM
avisitor's Avatar
Most relays come after the fuse that protects the circuit. Yes definitely check all the fuses.
Look at the dash and see if the check engine light comes on when key is turned to on position
Also listen for the fuel pump to run for a second or two (fuel rail prime)
juup91
Aug 1, 2017 10:38 PM
collegemike
Aug 13, 2011 06:05 PM
Jmrothrock29
Jun 28, 2011 09:20 PM
pistachio
Jun 28, 2011 02:41 AM
gowirelessmwebb
Jan 16, 2011 09:12 AM
