Location fuel tank pressure sensor hyundai sonata hybrid
Old Feb 23, 2023 | 12:30 PM
Denisfes's Avatar
Default Location fuel tank pressure sensor hyundai sonata hybrid
Hello. I need to change this part but I’m not finding the location. Remember, my car is Hybrid.
I tried to take the hybrid off to see if is in the same spot the regular Sonatas, but is not.
I really need help with that
Old Feb 23, 2023 | 12:34 PM
Before getting involved, what code were you getting?
Old Feb 23, 2023 | 12:36 PM
Denisfes's Avatar
Default Evap system tank pressure sensor
Old Feb 23, 2023 | 04:30 PM
Because folks interpret codes differently, please provide the code itself,thank you.
Old Feb 23, 2023 | 04:53 PM
Denisfes's Avatar
Default P0451
P0451
Old Feb 24, 2023 | 08:50 AM
You could be making an expensive mistake. Why ?
That pressure sensor is what lets the ECM know the Evap system check did not complete.
The purge valve could be involved and the pressure sensor is only reporting the check has failed.
You could keep replacing good parts or have someone with a quality scan tool run certain tests to determine just where the problem is located.
A CODE DOES NOT NECESSARILY INDICATE A MALFUNCTIONING PART, IT ONLY DIRECTS THE TECH TO THE SYSTEM THAT HAS A PROBLEM.
IT REQUIRES THE TECH TO TROUBLESHOOT THE SYSTEM USING THE RIGHT TOOLS AND INFO.
ata10
Aug 1, 2023 10:50 AM
oredav
Jun 5, 2023 08:18 AM
DRandy179
Nov 3, 2021 09:14 AM
NovaResource
Jul 13, 2009 11:04 AM
