Passenger side drl not working
Old Feb 9, 2020 | 11:11 AM
Coalminer's Avatar
Default Passenger side drl not working
Bought aftermarket led hi beams went to I stall them pulled pull off the the light plugged it in did t work so I plugged the original light back in now that one dont work now. Driver side works perfect now pass side do t no drl and no hi beam and worked before I unplugged it. I never took the bulb out of the head light. Ppl told me fuse but I cant find a fuse for that. And driver side works so please help it's a 2012 Hyundai elantra gls 1.8l
Old Feb 9, 2020 | 11:44 AM
In the engine compartment, there should be another fuse panel. In that panel should be two 15 amp fuses that are for the individual headlamps. See if you can locate them and check for a blown fuse.
Old Feb 9, 2020 | 12:03 PM
Coalminer's Avatar
Do you know by any cha ca what it's under I looked at both fuse panel and I cant find nothing labeled drl or high beam. I have all my other lights tho low beams work signals work to I will check for the 2 15 amp fuses tho. I'll pull them all thx for fast reply and help appriciate it
richardtc
May 23, 2019 04:30 PM
rodneez
Mar 23, 2013 11:19 AM
Gauge
Aug 1, 2010 07:41 AM
mcochran
Mar 7, 2010 06:07 PM
FellyConnelly
Dec 10, 2006 02:40 AM
