please help
Hey, this is for scott. I have been considering the same thing a turbo or supercharger. I hang with alot of tuners most own subies but, five of them have tibs with turbos. The main problem with running a turbo we have found is the compression ratio. In order to get the max out of your turbo you will have to by a compression plate and they rund between $300 and $400. We ran the math and basic maps and found that if you put on the compression plate and use a first gen turbo of an eclipse or event the hot side down turbo to the evo, using some misc. parts from forums and such. You will only spend around $2,000 and load almost 150 hp and do to the compression plate will not have the lag in the low end. Also, because you will using used or low end parts to save money, you leave yourself plenty of room to build. This design should allow you to run between 12 and 16lbs. of boost without any real stress on the engine. Hope this helps. I am planning on installing this set up in a couple of weeks, just looking for someone local to do the pipes and manifold.
