Engine & Internal Chat about beefing up your engine's insides here.
Tucson Engine Performance Increase?
Old 12-31-2016, 11:15 AM
ZombieHunter's Avatar
Default Tucson Engine Performance Increase?
I just bought a 2017 Tucson SE with the 2.0 four cylinder GDI engine, 6 speed auto/Shiftronic. I know it's not a performance engine, but was wondering what simple additions/changes could be made to increase engine performance/HP? I do not want a Cat-Back performance exhaust system. Is there anything else that would increase performance and still pass smog tests in CA, USA?
Old 01-05-2017, 10:29 AM
Default Hmmmm, no replies....
OK, I've decided to drop an aftermarket reusable dry air filter in it. I know there are some brands out there that can be washed and reused that don't use oil on them. Anyone suggest a brand?
Old 02-18-2020, 03:09 PM
Spanky555999's Avatar
Default K&N
If you dont mind spending the extra money you can get a great quality one from K&N. When I got mine I noticed the difference in about 1-2 weeks. The computer has to learn the difference because it dont think it made a noticable change at first. Also I learned a little trick with my 2013 Tucson 2.4L and I'm sure you have it too. If you take off traction control it makes my Tucson a completely different car. I'm sure you noticed when you slam on the gas you might get a slight hesitation. Many people think it's because the Tucson is underpowered. It is clearly not because without traction control I peel out and am doing 60 in what feels like 6.5 seconds. Try it and you will notice a different monster but hopefully you have good tires. I went through my front tired pretty quick enjoying it too much.
Old 02-20-2020, 06:31 AM
I don't know how much the changes pay off in normal driving, but if it provides plenty of jump off power when starting off, be prepared to spend some $$$ on motor mounts. Jack rabbit starts rips them apart and now extra expenses are knocking at the door.
talisay
07-11-2020 09:22 PM
josepepper
12-25-2016 11:17 AM
Pomogranic
03-02-2011 08:20 AM
Getzhombre
01-02-2009 03:02 PM
kimbo
12-02-2008 06:39 AM
Quick Reply: Tucson Engine Performance Increase?
