Autotrans color 2008 Accent?
Old 11-26-2010, 10:14 PM
mjb457's Avatar
Default Autotrans color 2008 Accent?
Ok just had trans serviced,,they changed fluid=said 7quarts,,trans shifts and operates great-fine,,but is dark in color,,is this normal or should I concerned>? 26k miles & plenty of warranty left..dealer says normal..advise thanks MJB
Old 11-27-2010, 05:48 PM
Accent with bottom pan is a 4.5qt (typically) drain and fill.. 7qt ? did they flush machine or drain and fill ?
Fresh fluid mix with remnants of old will make for some dark tint.. also note that the dye used in SP-III turns from red to brown / green-brown / black with age.. also smells foul too.
Old 11-28-2010, 04:55 AM
mjb457's Avatar
Default Trans Accent GS
They flushed filled,,, thanks for update it is dark but dark red on napkin,,feel better now,,(I thought pink like other cars,,MJB
river123
11-05-2008 10:25 AM
RknRusty
05-16-2008 11:07 PM
Snake7752
04-20-2008 03:11 PM
sp911
03-16-2008 11:52 AM
johann78
03-13-2008 03:03 AM
Quick Reply: Autotrans color 2008 Accent?
