water pump
Old 12-21-2008, 04:27 PM
MSPrentiss's Avatar
Default water pump
Wondering how much to install a water pump on a 1996 Hyundai Sonata 2.0L 16V[:@][:@][:@][:@][:@][:@][:@][:@][:@][:@][:@][:@]
Old 12-22-2008, 03:13 PM
jsinton's Avatar
Banned
Default RE: water pump
It's a sort of a job that is unwise to JUST do the water pump. Normally, since you have to remove the same parts, you also do the timing belt at the same time. So probably, it's similar to a timing belt job, which is $200 to $1000 depending on where you take it and what parts you replace. Why do you think you need a water pump?
abaton6
08-01-2009 03:29 PM
99sbm
01-18-2007 04:09 PM
gail
04-13-2006 12:00 AM
crappyass
01-03-2006 01:00 PM
LYAL
08-02-2005 04:51 AM
Quick Reply: water pump
