Need help various electronics not working in my car
Old 02-22-2010, 09:24 PM
mcochran's Avatar
Default Need help various electronics not working in my car
I just bought a 2000 Elantra and the radio, clock, dome light, and map lights do not work. The radio lights up when I turn on the lights but will not come on. I have checked all the fuses in the kick panel under the dash and the light bulbs in each light everything looks fine.
Old 03-06-2010, 09:56 PM
Define how you checked all the fuses ??
Did you use a DVOM and touch each exposed top lug of the fuse to verify source voltage ??
Look for a yellow or black connector in the cabin fuse block... when the vehicle comes off transport truck, the storage fuse is pulled to elimate draws to battery during storage... most all the items you post is affected...
Look in the engine compartment fuse box (look for power connector)
Old 03-07-2010, 01:04 PM
Bunklash's Avatar
Corroded or loose ground?
Old 03-07-2010, 06:07 PM
mcochran's Avatar
Haven't used anything other than my eyes to check the fuses, but I can use a voltmeter to check them.
Kodge
10-31-2011 03:39 PM
chuckanw
12-06-2010 03:19 PM
anita
04-27-2009 07:18 AM
mntbiker2008
08-24-2008 11:45 AM
billfl1
10-23-2007 11:42 AM
Quick Reply: Need help various electronics not working in my car
