How do I remove the factory radio in 09 Santa Fe
Old 07-27-2010, 12:17 PM
Bonnie Mazza's Avatar
Default How do I remove the factory radio in 09 Santa Fe
how do I remove the factory radio in my 09 Santa Fe,going to install gps system
Old 07-27-2010, 01:12 PM
Center Fascia Panel Replacement
- When prying with a flat-tipped screwdriver, wrap it with protective tape, and apply protective tape around the related parts, to prevent damaged.
- Put on gloves to protect your hands.
1. Remove the crash pad side cover.
2. Remove the switch assembly (A).
3. Loosen the mounting screw, remove the lower panel (B).
4. Disconnect the connector (A).
5. Remove the center lower garnish (A).
6. Remove the speaker grill (A).
7. Loosen the mounting screw, remove the speaker grill (A).
8. Disconnect the connector (A).
9. After loosening the mounting screw, remove the center facia panel (A).
10. Loosen the screws.
11. Disconnect the audio connector and antenna cable, then remove the audio assembly (A).
12. Installation is the reverse of removal.
- Make sure the connector are plugged in properly.
Old 07-28-2010, 08:20 AM
Thank you so much for the info .......................
cyberavenger
08-02-2011 09:50 PM
iroc
04-11-2010 06:29 AM
downunder94
10-03-2008 05:14 PM
Asperoth
09-19-2007 08:15 PM
sitinon32
05-07-2007 03:27 PM
Quick Reply: How do I remove the factory radio in 09 Santa Fe
