Brakes for 2008 Huyndai Sonata GLS
Old 07-22-2014, 12:00 PM
coolguy004's Avatar
Default Brakes for 2008 Huyndai Sonata GLS
Have a 4 CYL 2008 Huyndai Sonata need to do brakes.
Dealer charges approx $320 (all inclusive) this is rear brakes its down to 2mm.
Brake Masters(BM) is $100 , BM will be using semi metallic brakes.
How to decide what to use , spending $200 on the dealet seems to much.
Whats the best way to approach this?
Do I need Ceramic or semi mettalic?
Old 10-25-2014, 08:44 PM
otis66's Avatar
As long as the Rotors are okay go to Autozone and buy a set of ceramic brake pads and install them. If the Rotors are damaged ie the pad is worn so low that it is grinding on the rotor...replace the rotors too. About $37.00 for brake pads....$37.00 each rotor if needed.
Go with the ceramic. They are quiet campared to metalic. I'm not sure you can get metalic brake pads these days.
pats
11-22-2013 10:04 AM
tonykowalski
10-30-2011 11:23 PM
p0z3r
06-29-2011 07:23 AM
dcaldwell86
06-27-2011 07:24 AM
itsthebigb19
07-15-2009 07:28 AM
Quick Reply: Brakes for 2008 Huyndai Sonata GLS
