New here..And I have a brake issue
Old 12-07-2010, 04:22 PM
clinton's Avatar
Default New here..And I have a brake issue
While replacing the rear pads on my 05 Tucson, I snapped the two bolts while taking them off like a dummy. I know I probably have to replace the whole caliper right? Also if I replace 1 rear caliper do I have to replace the other side the same time?
Old 12-07-2010, 06:11 PM
What bolts did you break?
You shouldn't have to replace the whole caliper.
Old 12-07-2010, 06:21 PM
clinton's Avatar
I broke the two guide rod bolts. Also thanks for the diagram breakdown!! That is awesome! Do you have any for taking off the rotors as well?
Old 12-07-2010, 06:54 PM
Youl just have to replace the bolt and the guide rod that it goes in.
To remove the rotor
- remove the two "guide rod bolts" holding the caliper to caliper bracket
- remove the caliper
- remove the two bolts holding the caliper bracket to the spindle
- remove the caliper bracket
- remove the 2 screws holding the rotor to the hub
- remove the rotor
Old 12-07-2010, 08:48 PM
clinton's Avatar
To remove the rotor
- remove the rotor
Awesome Thanks alot! I did notice the rotor was missing 1 screw and the other was stripped. I did read in another thread for the Santa fe that those arent really necessary. I appreciate the help, Thank you!
Old 12-07-2010, 09:55 PM
Yeah, most of those screws that hold the rotor on get stripped when trying to remove them. I just drill off the screw head to remove the rotor. And, no, they aren't needed. The wheels lugs hold both the wheel and the rotor against the hub.
Old 12-09-2010, 12:43 AM
clinton's Avatar
I really appreciate the help! Thank you!
mtbrain3343
05-21-2012 02:30 PM
zerosoma
09-09-2011 12:57 AM
jalexa101
06-27-2011 06:49 PM
Efatnas
04-06-2010 11:04 AM
sbr711
03-14-2010 07:33 PM
Quick Reply: New here..And I have a brake issue
