Radio install for tucson 2008
Old 04-30-2009, 10:44 AM
Footballfan's Avatar
Default Radio install for tucson 2008
I need to remove the proper panels to get at my radio in my 2008 tucson. Can anyone out there help me? Thanks!
Old 04-30-2009, 12:30 PM
1. Disconnect the negative(-) battery terminal.
2. Remove the shift lever ****(A).
3. Remove the console cover(B), disconnecting the shift lever connector(A).
4. Remove the upper plate from the transmission shift lever, then remove the 3 screws holding the center facia panel.
Remove the center facia panel(A) and disconnect the wire connectors.
5. Remove the audio unit after removing 4 screws.
6. Installation is the reverse of removal.
stlwaco
03-12-2012 11:27 AM
mikeyboy_79
11-21-2010 03:25 AM
qqlove
07-04-2010 04:46 AM
Boy_Narf
01-10-2009 10:08 PM
alevine
09-26-2008 02:36 AM
Quick Reply: Radio install for tucson 2008
