Washer Pump Power
Old 12-03-2010, 12:40 PM
Doitall Dad's Avatar
Exclamation Washer Pump Power
I have no power to the washer pump and cannot determine the fuse/solenoid which activates it. Please help!!!
Old 12-03-2010, 12:50 PM
First things first, what model/year XG?
What makes you think the washer pump isn't working?
Are you sure the tank isn't empty and that the lines aren't clogged?
Are you sure the wire to the pump isn't getting electricity?
Maybe the pump is dead?
The fuse you are looking for is the one marked WIPER in the fuse box in the dash.
Old 12-06-2010, 10:06 AM
Sorry for not filling in the detailsl. The model year is 2004. I checked the wiper fuse which also forwards power to the wiper relay. The wipers work. There is not a set of contact to forward power to he pump. I next located the pump from a drawing at a NAPA store. I removed the wheel well cover and disconnected the plug to the pump. I checked the voltage to the pump while actuating the wiper lever on the stearing column. No voltage. I need to know if there is a relay or anything else within the circuit which brings power to the pump. Thanks for your help.
Old 12-06-2010, 10:54 AM
There is no relay and the fuse is the same as for the wipers. If you are not getting volatge then either the wiring is bad or the switch is.
Old 12-18-2010, 10:19 AM
Default Washer Pump & Defogger
Thanks for your help NovaResource. The switch in the wiper controll assembly on the steering column was the proplem for power to the pump. I also had to replace the pump after I had power to it.
I have another problem which showed up. the rear window defroster is not working. Can you share what is all in that circuit?
grlgeorge
02-06-2012 12:02 PM
bucannon
04-14-2009 05:09 PM
bumbleberry
01-18-2009 10:04 PM
sarahinmedford
01-02-2009 02:22 PM
pneandy
06-06-2007 11:16 AM
Quick Reply: Washer Pump Power
