1998 Sonata cracked gas tank
1998Sonata, 150,000 miles. This is mechnically sound car butFilled up tank recently and noticed gas smell and dripping. The tank is cracked at the top. My question is: tanks are at least $270 + the labor to install, not sure if I want to spend that. Any source for used tanks out there? Any experiences to share? I wonder if present tank is safe to use, if only a few gallons at a time in the bottom of tank. Thanks for your input. I checked on recalls, it was pressure tested at the dealer before I owned it, and checked out ok. The dealer says they will not replace the tank.
I would *not* use a tank out of a junk yard; it's going to be old and likely to leak as well. I think it changing it out yourself is do-able if you do any of your own work. People do their own fuel pumps all the time; this just takes it one step further.
pjbjleal
Nov 2, 2011 06:40 AM
SDMJL
Oct 19, 2006 11:53 PM
