2002 elantra short on Signal/light
Old Aug 11, 2023 | 02:30 PM
johnbgarrison's Avatar
Default 2002 elantra short on Signal/light
for a while now on my 2002 Elantra when i use the turn signal it will often turn off the dash lights for a moment (short). Hasn't been a big deal. Last night the dim/lo headlights would not come on, bright works fine. I swapped the fuses and the problem stayed with the lo beams. I am assuming that the problem is in the signal arm. The low beams do come on when i pull the arm forward, and the hi beams come on and stay on when i push it back into the hi beam position.
So my main question is what part do i need. Not sure what you call that part. opinions?
THanks
Old Aug 11, 2023 | 07:57 PM
Hi John,
IF,,,,,,,,,,,,,,,,,the part that you need requires the steering wheel to be removed,,,,,best to look into what is required before purchasing a part you may not be able to replace without some special tools. If your vehicle has a tilt steering wheel it could require a special tool you most likely won't have.
Sometimes a sw assy can be replaced without removing the steering wheel, but not sure without looking at your vehicle.
Again it might be something other than a switch.
You might consider obtaining an estimate or two before starting the job.
pkschul
Dec 8, 2021 01:53 PM
presward
Aug 23, 2017 11:40 AM
streetslick
Feb 1, 2013 08:43 PM
Gusterlover
Oct 6, 2012 02:19 PM
Erixon
Aug 9, 2011 08:29 AM
