2002 Sante Fe window rattling
Old Aug 4, 2005 | 10:28 AM
left90's Avatar
Default 2002 Sante Fe window rattling
My driver side door window seems to be loose, if you close the door with the window rolled down there is rattling noises. I've tried to remove the door panel, I removed every screw I could find but the panel still won't budge. Can anyone tell me what I need to do to remove the door panel, whether there is more hidden screws, special tools I need, or just a trick to pop it loose. Also would anyone know if the looseness is something that is most likely an adjustment issue or most likely in need of new parts?
Old Aug 8, 2005 | 06:40 PM
hyundai tech's Avatar
Default RE: 2002 Sante Fe window rattling
You must remove the screw in the inside door handle plastic.Remove the screw in the
inside pull handle.All screws on surrounding door panel.Corner upper piece facia (by door mirror) unsnap bottom and lift up . Now for the rattle.I have seen the door lock rods going to the actuator come off and rattle.You can usually duplicate this condition by moving the door back and forth .
Old Aug 13, 2005 | 12:46 AM
hyundaimastertech's Avatar
Most likely it is the bolts are loose that mount the window to the regulator. how many screws did u take off the door panel? did you take the little delta trim piece off?
Old Aug 15, 2005 | 02:22 AM
Ooooooooohhhhhhh boy.
Old Sep 1, 2005 | 02:06 PM
left90's Avatar
Finally got time to do it and I found the bolts holding the window to the regulator came loose as you stated. Thnx for the info.
hw1355
Oct 31, 2011 08:15 PM
praaa_5
Oct 1, 2010 11:23 AM
Alienmidget
Jan 13, 2007 08:41 PM
LeChuck
Dec 22, 2006 10:21 AM
stiles88
Mar 30, 2006 08:30 PM
