Engine not heating up
Does any one else having a engine heating up problem since the weather has become colder mine will not heat up even after driving more than 15kms. The guage does not even move and the upper rad hose is luke warm and the lowerrad hose is cold. The dealer says they replaced the thermostat. But it still wont heat up. It is a 2008 accent 1.6l 5spd man.
If its below 0 F (-20 C?), it sometimes help to place a cardboard air dam on the front side of the radiator. Cover about 1/2 to 2/3 of the radiator surface. This is the same idea as the canvas air dams you see truckers use on the front of semi's in cold weather. Since this is a manual, you shouldn't need to worry about blocking the transmission oil cooler. Remember to remove the cardboard when the weather warms up.
