Hesitation from standstill only, warm or cold
Old Nov 27, 2007 | 07:52 AM
Mainely Tucson's Avatar
Default Hesitation from standstill only, warm or cold
05 Tucson and I love it . Purchased used Aug 06. Last winter on first really cold day (0 F) it balked when accelerating from standstill. Tried drygas. Problem continued through summer. Intermittent but happens more than less, and only from standstill. Embarrassing to bump my way through an intersection. Recently it did stall once, when fully warm. Any thoughts, except a full computer survey?
Old Nov 28, 2007 | 10:50 AM
Doohickie's Avatar
Default RE: Hesitation from standstill only, warm or cold
Not really. It's still under warranty, right? Just have the dealer look at it.
Old Dec 11, 2007 | 06:38 AM
mahout's Avatar
First, the slow ignition pickup, which leads to stall, is part of computer function. But make sure your timing is correct and also use some carb cleaner to make sure your fuel system isn't restricted.
Second, make sure your spark plugs are good, especially the correct heat range. Plugs too cold can make start up hard as well as causing stalling as a result of carbon fouling.
Third, check your accelerator cable to make sure that there is no delay. a kink or bow in the cable can cause the throttle plate to snap open, suddenlyjerking open which will also cause stalling.
Old Dec 24, 2007 | 09:33 PM
daquill's Avatar
Check out my post of 12-24-07. I have the exact same problem with the exact same vehicle. Did you resolve your problem? What was the solution? Thanks for any light you can shed on this...Dave
Old Dec 26, 2007 | 11:39 PM
madindian1's Avatar
most likely it's the intake hose at the maf sensor that is loose.
DrGreve
Nov 6, 2011 03:32 AM
jack_
Oct 23, 2011 10:35 AM
serge_saati
Jan 22, 2009 05:39 PM
conorsdad
Jul 31, 2007 11:04 AM
