Mystery Front End Noise 2013 Sonata
Old Jun 5, 2023 | 11:49 AM
Quarks's Avatar
Default Mystery Front End Noise 2013 Sonata
I have a problem with noise coming from my front end. When I go over hard bumps I hear a klop klop sound rather than a more mued thump like it used to do. I have had new struts installed, new sway bars an new brake hardware and still makes the noise. I ave had 3 mechanics check it out and they inspected it including the bearings, bushings, etc and cannot find anything wrong. Now here is the kicker. When I go over the bumps and slightly depress the brake pedal the noise goes away and all I hear is the normal thump. I go back over the same bumps in the road without the brae pedal depressed and I hear the klop klop. I have done this many times with the same results. For the life of me I cannot figure out what it is.
Old Jun 5, 2023 | 12:39 PM
When was the last time brake pads were replaced?
I ask this because it sounds like whoever replaced the pads didn't install the caliper slides correctly or didn't replace the parts that prevent the calipers from banging.
trggobog
Nov 28, 2022 07:34 PM
ironcot
Oct 2, 2021 02:13 AM
SillyB0y
Jan 13, 2014 06:11 PM
hoffy5
Jul 19, 2010 06:44 AM
tszshingt
Jan 24, 2010 09:59 AM
